I am replacing Crane acrylic taps on my sinks and tub taps (with same OEM version)... but the H and C "tabs" that "push on" keep popping off. Any suggestions?
Printable View
You may need to bend the little spring fingers out slightly. In a rental once I had that problem and cut short plugs of memory foam style earplugs to provide a little more pressure for the fingers.
I suppose small balls of plumber's putty would work.
No, I put the foam plug inside the fingers so that as the memory foam expanded, it pushed the fingers outward.
http://www.supplylinedirect.com/asse...r-312-1201.jpg
