monday morning a boatload of calls
got a boat load of whirlpool calls today...
the first was from a poor guy in Houston, with a 1 year old Whirlpool heater installeled up in his attic.. behind the furnace.... wanted to know how to reapir the unit.. he has got troubles
the second guy was from San Deigo, the previous owner had majic markerd the heater with dates every time the reapir man fixed that dog, it had been repaired 5 times in the last 6 years... i told him to jsut throw it out , and he agreed...
then it really began...
I get 4 more calls scattered through the day...
all from Indianapolis, wanting me to repair their Cess-pools, all of them about 2 years old...
I told them to call Raji in India and have the parts sent to them.... then call me back...:D
.This would almost be funny , if it were not for the people that have beed screwed so deeply by whirlpool...
5 Attachment(s)
Flame Lock Whirpool Water Heater model NO.?
I have purchased already 3 Whirlpool Flame Lock water heaters from Habitat. These were donated to Habitat for sale by Lowe's, obviously warranty returns with problems. All 3 had removed model and serial numbers so I do not know what models I have. To order parts I need model numbers, otherwise Whirlpool can't locate the replacement parts. Can anyone help me using the pictures below to identify the model? The thermocouple has right-hand threads and manifold tube also right-hand threads. The water heater is similar to what Lowe's has on the floor now, but my does not have the Thermal switch.
When purchased the problem was not thermocouple but the high temperature sensor (HTS) in all 3 cases. That is an internal part (penny value) and I suppose the whole thermostat (gas control valve) needs to be replaced. In first instance I got around by taking the HTS from the 20 year old water heater I was replacing. Second and third time I took it from new similar valves that I happened to find at Habitat and bought it cheaply. These HTS are very easy to replace, problem is to get it. If someone knows where to buy it I will appreciate the information. See the last picture below that shows 2 HTS, one as removed from the gas valve and one with insulation stripped. It would be very easy replaced (silver solder) if the electronic component was available to buy. I do not have the problem with clogged screens. One water heater is installed outside as shown on the picture, one in my garage elevated above the floor 18”. Also I need outer doors for both. My email jfkn@cox.net.
I think it is Ultra Low Nox
I think that it is called Ultra Low Nox. Judging from this manual http://www.whirlpoolwaterheaters.com...315422-000.pdf that depicts the same burner assembly.
What is the "Flame Lock" feature? Thanks. :)
Its a piece of junk, on so many levels
Quote:
Originally Posted by
RPlumber
So at the end of the day, we have one guy saying the screen just gets clogged up, another saying it's too small, another saying it's both. One saying it's the gas valve, many more saying it's the thermocouple, and one guy saying it's the thermal switch.
So do any of you know for certain what the problem is?
Which came first, the chicken or the egg???
here is a link to the low knox that this fellow has...
this will be a ball trying to figure out what they screwed up on that model....
http://www.americanwaterheater.com/p...pdf/U_LNOx.pdf
