Whirlpool Flame Lock gas valve/thermostat
I have been having issues with this water heater for quite some time (model # FG1F3030S3NOV). The problem seems to be with the gas valve/thermostat. The BFG conversion kit has had to be installed (according to Lowe's and Whirlpool this would fix everything). Needless to say, it did not work. Then I was told that the flame trap must be dirty or clogged. This was not the case due to fact that the heater was place on blocks when installed just for the purpose of cleaning the flame trap which would have been almost impossible to access otherwise. After the kit did not take care of the problem, I changed the gas valve and immediately had a pilot light after just a few seconds of holding down that blasted red button. I just recently had to change the gas valve again (item #6910555) for the second time, after having to repeatedly light the pilot light over a period of 3 months to the point that it finally would not light at all. And yes it is exactly the same as the first replacement so I can figure on about 6 months to one year of hot water before I have to replace it again. In my case, it had nothing to do with the thermocouple, or the flame trap, or the conversion kit, as I was initially told by Whirlpool. The good news is...Whirlpool ground shipped me the gas valve this time at no cost, however I was told this would only be a one time shipment (this just tells me that they have not rectified the problem and fully expect it to happen again). They were extremely accomodating this time (kind of scary since this has not been their norm). So if anyone is still having problems you might want to call Whirlpool and see if they will ship you a gas valve as well. Even if you don't need it now.....you will eventually.
Anyone seen an increase in natural Gas bill?
My husband installed the Whirlpool Flamelock "enhancement" kit some time in November 2008. I opened our gas bill for 11/31/08 to 12/31/08. It had tripled. We were gone 10 days of that period as well. We have gas heat, but in 15 years, we have never had a bill that high and we both like the house cool - around 69 in the winter.
The only thing that has changed was the replacement of that part in that Whirlpool water heater.
Has this happened to anyone else?
Thanks.
The Dreadful Whirlpool Water Heater
I installed the "T/C Enhancement Kit" myself and all went well. I also had great service with all whom I spoke with on the phone. However, I did make the mistake of ordering the kit "Next Day" for $20 at (http://www.flamelocksupport.com/kits.aspx) on Thursday evening expecting to receive it Friday. Wrong! I would not get it until Monday as they placed the shipment order on Friday. (order before 3:00 pm). The lady I spoke with said that I could place an additional order "Saturday Delivery" for $30 as long as I did it by 3:00pm (it is now Friday morning). I then called other Lowe's stores near my location and found the kit I needed (Type A). They said they would put my name on it and leave it at the service desk. It was a 40 mile one hour drive (very bad weather) but the kit was FREE! Great, now I can get started!
I started on it Saturday morning and encountered only one problem. This kit is fairly easy to install as long as you follow the instructions provided. However, the one problem I ran into was installing the 1/4 inch pilot tube and compression fitting into the valve. The fitting did not hold the line in! Oh S**T!!! This fitting is a one time shot as you will not find it in any hardware store! Here is a very helpful tip: When installing this fitting, the instructions tell you to: (1)screw the fitting into the valve finger tight only at first(this is correct) (2)push the 1/4 inch pilot line up into the fitting all the way until it comes to a dead stop(wrong)...this is actually correct but, when you tighten the fitting while holding the line in, you should back the line away from the dead stop no more than 1/16 of an inch. This allows the line some space to move forward a little when you tighten the fitting. (I believe that when I held the line to a dead stop and tightened the fitting, the line had no space to move as the fitting clamped onto the line. Therefore, when drawing the fitting up tight, the line broke free from the fitting as it had no space to move once clamped into the fitting. (I tried to explain this the best I could!)
1st pic: Gas valve with everything removed..........
http://www.terrylove.com/images/wp/wp_gas_control.jpg
2nd pic: empty Combustion Chamber..........
http://www.terrylove.com/images/wp/wp_chamber.jpg
3rd pic: Burner assembly..........
http://www.terrylove.com/images/wp/wp_burner.jpg
The dreaded Whirlpool Water Heater!
I installed the "T/C Enhancement Kit" myself and all went well. I also had great service with all whom I spoke with on the phone. However, I did make the mistake of ordering the kit "Next Day" for $20 at ( http://www.flamelocksupport.com/kits.aspx ) on Thursday evening expecting to receive it Friday. Wrong! I would not get it until Monday as they placed the shipment order on Friday. ( order before 3:00 pm ). The lady I spoke with said that I could place an additional order "Saturday Delivery" for $30 as long as I did it by 3:00pm (it is now Friday morning). I then called other Lowe's stores near my location and found the kit I needed (Type A). They said they would put my name on it and leave it at the service desk. It was a 40 mile one hour drive (very bad weather) but the kit was FREE! Great, now I don't have to spend another $30 and can get started on it today!
I started on it Saturday morning and encountered only one problem. This kit is fairly easy to install as long as you follow the instructions provided. However, the one problem I ran into was installing the 1/4 inch pilot tube and compression fitting into the valve. The fitting did not hold the line in! Oh S**T!!! This fitting is a one time shot as you will not find it in any hardware store! Here is a very helpful tip: When installing this fitting, the instructions tell you to: (1)screw the fitting into the valve finger tight only at first(this is correct) (2)push the 1/4 inch pilot line up into the fitting all the way until it comes to a dead stop(wrong)...this is actually correct but, when you tighten the fitting while holding the line in, you should back the line away from the dead stop no more than 1/16 of an inch. This allows the line some space to move forward a little when you tighten the fitting. (I believe that when I held the line to a dead stop and tightened the fitting, the line had no space to move as the fitting clamped onto the line. Therefore, when drawing the fitting up tight, the line broke free from the fitting as it had no space to move once clamped into the fitting. I hope you understand what I,m talking about(I tried to explain this the best I could!).....I did get lucky and managed to find a way to reuse the fitting which failed. Wheeewwwww!!! It is now Sunday morning at this time and I have hot water!!! Oh.....and I still have the other kit still on the way Monday morning also! I would be glad to help anyone with any questions concerning this particular model (fg1f4040s3nov)! ( guitarzan_brad@yahoo.com )...............
Here are a few more pictures to check out.
