at least you all agree on something....
whther the chicken or egg came first...
at least you all agree that
its a piece of crap.....
Need help with Gas Valve /Thermostat Replacement
I too have one of the Whirlpool Flame Lock water heaters that I've had for over 5 years now. I just recently had a problem where the pilot light won't stay lit and Whirlpool sent me a whole replacement assembly that I replaced with no problem, but the pilot light still wouldn't stay lit. I troubleshot per the flow chart supplied and called Whirlpool with my troubleshooting results and they overnighted a Gas Valve/Thermostat assembly to me. My question is there is a plastic cover that seems to be fitted over the probe that goes inside the water heater. The instructions don't say anything about removing the plastic prior to installation and naturally customer support is closed. Does anyone know if the cover should remain in place? Also, the customer servise rep didn't mention anything about the filter, but after reading all of the complaints I'm definitely going to check it.
Right-threaded vs. Left-threaded
I recently received my replacement manifold per the lawsuit. No instruction were provided for those strange new parts. I stored it away as a spare part. Well, like everyone else that owns a Whirlpool Flame-Lock, I ended up using it sooner than later. I only wish I had found this forum before I tried to put it in myself. When I began to screw in the thermocouple nut - without the adapter provided in the kit - I had the hardest time getting that new right-threaded nut to go in the left-threaded hole in the controller. Imagine that! I'm thinking, "Those idiots can't even get their parts to match!" So I did the unthinkable and just tried to start that left-handed nut into the hole as if the nut was right-threaded. And guess what! It went in with little resistance! I'm thinking to myself, "Now I could have sworn that puppy was left-handed when I took it off. Maybe, it wasn't." It was only after reading this forum that my fears were confirmed: I obviously re-threaded the nut or the hole. Either way my water heater is working again. My question to you all is this. How necessary is the reset switch? And if it IS necessary, should I try to "re-thread" yet once again?
I suppose I understand your hesitation in answering my question given the issues of liability this water heater is surrounded with. My understanding is that the purpose of the reset switch is to lengthen the life of the thermocouple. I will, therefore, leave the reset switch dormant until either 1) the next time I have to replace the thermocouple or 2) I decide to replace the water heater. The orifice theory intrigues me. I hope to hear more discussion about that.
their high limit re-set switch....
the high limit was designed to keep the thing from overheating.....
and of course it is totally half assed designed
on the whirlpool unit....
considering that Whirlpool sends this kit out to
un-lliscensed amatures to install themselves
without instructions...
http://www.weilhammerplumbing.com/galleryiii/
