I have a challenge with a Water Pump that wants to run continuously.
Pressure never gets to the cut off point.
Tank seems to be OK however, I will have to check if pressure holds as it was very low ( 15psi).
Any other suggestions from you folks?
I also suspect that my pump may be somewhat worn down so I may have to repair or replace.
Any suggestions appreciated.
BPRO
