If you do leave it alone you are probably leaving a bomb in their home....
Printable View
Redwood, you know that this is a total load of hooey..
I do think it is something that I might start to mentioin to my customers when I go into their homes...
I would inform them that it would be a good idea to change it while I am at their home for $$ 125.00..
I will not test the T+p valve cause I know it will leak...
but I will gladly change it for safety sake
I dont think i will get many takers.....even at 125
not in this economy:confused:
Well boys, in 25 years owning personal and renting homes, never messed with them. Not worth the time etc..Most time the tank will be shot before the valve...YMMV.
Actually Mark I do test them and far more test good than fail.
Of course your water conditions may be quite different from what I routinely see.
I'm not kidding when I say bomb and you know it Mark...
Of course the need of this critical safety device is limited to a situation where the thermostat has failed causing run away heating of the water and the ECO has also failed. It is a third in line device. But it is highly desirable to have it working.
