How do I remove the brine piston assembly at the control head of a Fleck 2510?
Need a bit of help. The brine piston in my Fleck 2510 control head is stuck and won't move in or out. Is there any way to free it or should I replace the brine assembly? The piston is gray plastic and the assembly that it fits in is brass. If I need to replace it, can you tell me how to remove the assembly? The brass assembly appears to have shoulders for a wrench. Do I put a wrench on it and unscrew it to get it off? I don't want to force it and break something. Thanks for your help.
Not following you - we may be speaking about a different model
There are no back nuts on the gray tube on the back side of the piston assembly. I don't know what you are referring to as an "injector block". The gray piston is encased in a brass assembly. I think we must be talking about something different. Tomorrow when I get home from work, I'll take a photo of the piston and brass assembly and post it. Thanks for your patience. I appreciate your help.
