thank you for the pictures
Bored again this morning
thank you for the pictures.....
1. the junction box is about normal that is no big deal
2. the water lines look pretty crappy and they should have been changed out to new flex connectors.... that will come back and screw you eventually......they cost about only 10 bucks each to clean that up
3. I guess the chimmney is no big deal, but it looks crappy just hanging there....it does keep the water heater cool with ventilation, I guess....??
4. The PVC issue is basiacally a joke .... it will work ok for probably 100 years... but the cpvc is what you are supposed to use if it gets inspected....
where does it release down to... just down to the floor or into the crawl space???
5 the waterheater should have been installed in a pan with the pop off pipe dropping down into it... then the pan should have been piped into the crawl space if you have one... you can clearly see where the old heater already damaged the tile on the floor..
as far as the water heater exploding, it aint gonna happen too often..
that job is worse than I have seen the lowes guys and home depot do work for... I quote it at no more than $250.00.....
actually most water heaters dont go through the roof due to the
walls and surroundings... they usually make a good concussion
that can damage all surrounding appliances and walls
if it really blows, it could take out some windows
it all depends.... but flesh and bone dont want to be
anywhere near this event.....
http://onsmartpages.com/weilhammerpl...s/DSC04138.JPG
will work till it fails....
Quote:
Originally Posted by
Redwood
I guess you are right Mark...
It will do fine until the day it is actually needed....
Then it will just look like those pvc drain lines someone puts in a commercial kitchen for a dishwasher drain...
the restraunt pvc pipe is a great example of what steaming hot water does to pvc pipe...
that is probably about right,,, the pipe might warp from intence heat or steam...but it wont actually melt away......
I feel as long as it dont go down into the crawl space it would work fine...
we did have one that was piped into someones crawl space that caused massive damage one time...
the releif valve popped off and kept popping off for about a month or two...
the people were too stupid to figure out what was going on and eventually the steam in the crawl space warped the plywood floors throughout the center of the home....
you could write your name in the humidity on all their windows.
the insurance company was not amused:cool:....
