Irrigation on house system
Hi, here is my question, we are on a typical well setup with pressure tank etc. The irrigation is on the same system so when it is activated, the pressure drops in the tank and the pump kicks on. What is the best way to separate this system. I get lots of air in the house when the irrigation is running and I turn on a faucet indoors. I think there is a leak in the irrigation system also because I notice the pump running when there has been no water useage in the house. It is either that or my check valve at the pump is bad but it was just replaced when we moved in and we don't have a lot of sand in our system. Any suggestions would be appreciated. Also how do I boost the pressure to the faucets at the end of the line. All of my plumbing is accessible via the basement so I could just about do anything.
