problem ..scalding hot water from electric water heater
I have a 60 gallon State Select electric water heater that is 4 years old.
Recently it started putting out scalding hot water. I shut off the breakers and looked at the top and bottom thermostat and set both to the lowest temperature. It worked okay for two weeks,
but the scalding water problem started again. Has one or both of the thermostats gone bad?
Any other suggestions on what the problem may be? Thanks for you help
Could loose circuit breaker cause the problem???
When shutting the double breaker I noticed the breaker was loose on the clamp side..I shut main and fixed the loose clamp on the breaker..is it possible the loose breaker somehow caused the intermittent scalding water????
