jw and Thatguy are borth correct in their own way. In terms of voltage, the key is in reference to what? Voltage is the electrical potential between two points. If you want to talk about the voltage making a current through the body, you need to know:
1. Resistance of the body between the points of contact. This can vary greatly between people as well as what you are wearing (gloves, shoes, etc.)
2. The voltage
difference between the point of contact. For intance, you could hang a metal cage in the air, stand inside, and charge the thing to 700kV. Will it kill you? Nope. Will you feel a shock? Not likely. Everything in that cage is at 700kV, so the voltage potential across your body is 0v. Some might thing that different parts of the cage might be at different voltages due to resistance of the metal, but this is not the case. You only get volatge drop if current is flowing. If the cage is isolated, then everything will be at the same voltage. See "Faraday Cage".
http://www.faraday-cage.com/wp-conte...aday-cages.jpg
Using current to define damage to the human body is a better correlation than voltage. However, from a safety point of view, voltage is sometimes more useful. Voltage of a circuit is known. The current is not. The circuit might be able to flow 100A, but that doesn't mean that it will flow 100A through your body. By estimating body resistance and assume that the full potential is across the person's body, one can determine the risk to that voltage. For instance, I can touch both sides of a car battery that can supply a couple hundread amps when starting a car and feel nothing. If I grab onto something that is at 40kV and can only supply, 1 amp, I am probably dead.
Terry: I have a doctorate, and I hope that I have common sense, but I know there are a lot of smart people out there that do not have common sense. It is amazing how far they get without it. I don't get it. I also know a lot of smart people who have no practical knowledge. Can't even change the oil in their car or do simple fixes around the house.
OP: If it were my house, I would bond the copper. It wouldn't work as an electrode, but would cause the breaker to trip if the piping were to become energized due to faulty wiring.
