I need help. I just built a phase converter with a 15 hp motor. It starts right up, but the voltage is not balanced. L-1 is 122 volts,L-2 is 122 volts, and L-3 is 180 volts, What do i need to do to balance the three legs? thanks
Printable View
L3 is the wild leg. it will always be higher voltage. You want to balance the amps, not the volts.
