Even Georgia freezes. Running water piping, even insulated, as you indicate is asking for problems. Good luck.
Printable View
Sounds like you got it covered. Here's some info that might be helpful in the fututre:
- GA Amendments to IPC (hardly anything changed): http://www.dca.state.ga.us/developme..._effective.pdf
IPC allows the following for Water Service Pipe:
1. Abs
2. Asbestos-cement
3. CPVC
4. Brass
5. Copper
6. Several flavors of PEX
7. Ductile iron
8. Galvanized
9. PB
10. PE (several flavors)
11. PP
12. PVC
13. SS
However, only the following is allowed for Water Distribution Pipe:
1. CPVC
2. Brass
3. Copper
4. Several flavors of PEX
5. Galvanized
6. PB
10. PE (only PE-AL-PE)
11. PP
12. SS
So no PVC or PE (except of the composite PE listed). I have seen nothing directly in IPC about PVC (or other materials) being outside/exposed to sun. However, they define the "Water Service Pipe" as being underground and outside of the structure. If the material is not allowed to be a "Water Distribution Pipe", then the "Water Service Pipe" must terminate at/before the full open valve located at the entrance to the structure.
In addition to PVC not be listed as a "water distribution pipe", there is an additional restriction for hot water that says that the pipe must have a pressure rating of at least 100 psi at 180F (which PVC would fail that test as well).
Well anyway, I would like to thank the OP for checking with his local code authority. It is always a good idea to find out what particular amendments that your state, county, city or whatever may have adopted. So perhaps a lot of confusion could have been avoided if that advise had been proffered in the first place and I apologize for not doing so.
Well then, that about wraps it up fellas. :)
