Soap suds coming out from drain pipe for my washing machine no problem with water
Please help !!!!
We recently installed tiles in Laundry room. For that we moved washer and dryer and connected back. The problem started after we put it back, is water is draining well without any issue, when spin cycle starts the soap is coming out from the drain pipe. We called Maytaq service, they said run the washer with water, the soap in the pipes will go away, nothing worked.
The local home depot guy said there must be air lock in the vent pipe. I don't understand where is the vent pipe.
By the way we blown out the insulation in our attic, the guys put the machine out side and did the blown out the insulation. Is this caused the vent pipe closed ?
I am eagerly looking how to resolve the problem
thanks in advance
Krish
Plumber snaked entire drain - everything is clear
He said there may be problem with washing machine, when the machine reaches the spin, he saw what is coming from the drain pipe, only soap suds coming already water drained out. He said I have never seen washing pushes water first and then soap suds. Since soap is lighter that is the reason it is coming out from the drain pipe.
Is it true ?
Any one think about problem with vent
regards
Krish
