Vespin II, CST474CEFG Watersense Toilet Review, comments and pictures.
TOTO has a new model of the Vespin out, the Vespin II
Universal height bowl, 16-1/8" before you add the seat.
Siphon jet flush using 1.28 gallons, Watersense so it gets the water saving rebates
Double CycloneŽ flushing system, low consumption (1.28GPF/4.8LPF
800 grams, so it has a very good flush.
Comes with a standard 12" Rough-in, but can be changed to 10" or 14" by changing the adapter.
Elongated bowl with Sanagloss in Cotton White, Colonial White, Bone (Almond) and Sedona Beige (Biscuit)
Also comes in Black, but without Sanagloss.
Spec sheet pdf
http://www.terrylove.com/wc/toto/cst474_angle.jpg
TOTO Vespin II, CST474CEFG
http://www.terrylove.com/wc/toto/cst...h_pedestal.jpg
and front view
http://www.terrylove.com/wc/toto/cst474_front.jpg
And view at the wall.
http://www.terrylove.com/wc/toto/cst474_side.jpg
Toto Vespin II CST474CEFG with SS114 Softclose seat.
Comfort Height bowl
800 Grams MaP
Sanagloss
Skirted bowl
This bowl was installed on a 13-1/2" rough-in using the 14" Unifit adapter.
The water shutoff can be as close as 5-1/2" to the left of center, unless it's higher off the floor, and then it can be even closer to center.
This shutoff had been replaced with a new 1/4 turn valve with brass nipple through the wall.
Installation was by James Love of Love Plumbing & Remodel 206-949-5683
In some of the older Seattle homes, the old toilets had been wall mounted tank toilets.
Those typically are 14" rough-in and need a flange repair to use standard closet bolt connections at the flange.
Everything is on the truck for that.
Vespin II Supply Location
I am interested in the Vespin II, and my water supply is 7" from center, 5 1/4" high and sticks out from the wall 3 1/12". Terry has posted that the Vespin II works at 5.5" from center, but the picture looks like the supply is much higher off the floor to not interfere with the skirt. Would my spec's work OK with or without a Dahl valve for Toto. Thanks much.
