Originally Posted by
Fireguy97
That might be fine and dandy, but don't forget to include that the replacement has to the EXACT manufacturers replacement part for this assembly, otherwise the device will fail the test, and then will have to be replaced yet again. You can't just replace the number one shut off (ball valve) with any ball valve. Backflow assemblies don't work that way.
Cygar, as hj said in an earlier quote, who did you actually contract and pay. Did you contract the plumber yourself? If you paid the General to 'get the job done', the it's his problem. If you are the one that paid the plumber, then it's your problem. You are right though, you shouldn't have to pay twice.
That is a different problem might have been caused by this, but a good irrigation contractor would have caught the fault on blow out. But then again, you don't blow high pressure air through a backflow prevention assembly either, you drain it and blow out after the assembly.
Mick
