Union or drain coupling. Yep, Watts are plastic. I think there is another company making plastic ones too. Maybe Gator bite?
Printable View
Never needed a jet sweat for a drain...I would use a banded coupling.....a union leaves you in the same situation, unable to sweat a joint because of water, unless you are installing a valve...
quote; Repair the leaking pipe with a solder coupling,
NO conscientious, law abiding plumber would repair an underground leak inside the house with a soft solder joint. And unless you use oxy/acetylene brazing or silver soldering in a hole is almost impossible. But it WOULD require a lot more billable time. I have not seen a Sharkbite large enough to repair a drain.
and while Sharkbites are OK for underground repairs per the Sharkbite info. I would never use one of them for an underground repair...even if approved localy...
Who said anything about underground or under slab? That be a whole different kettle o fish.
Oh yes, thanks. So then we're talking brazing the joint or a dresser coupling.
It's 3 months old Eddie, let it die
Good idea!
No point in arguing when the difference between a SharkBite and a Schwinn Coupling can't be realized...
As far as relying on EPDM o-rings to hold back water under pressure I guess we'll just have to sweat it out over all the Pro-Press, flushometers, faucets, mixers, and other stuff that uses o-rings to seal...
I'm Sweating... Some of them time bombs have been ticking 35 years without a problem yet...
Oh well...
I'll continue to use SharkBites in situations where there use is warranted...
They have saved the day for me and my customers on many occasions...
They are a valuable tool in the plumbers tool box, but they aren't the only tool in there...
The key is knowing when to reach for it....
you want a 5 minute house?
