How to Construct a Solar Water Heater
Employing solar power to heat water symbolizes one of the most logical methods of generating hot water that you can find. Why use un-renewable resources when we have an over abundance of energy emitting from our own sun? It is rapidly becoming an acknowledged impression that the best way to diminish energy consumption is by building your own.
During the construction phase of this project, you would need to paint your water tank with flat stovepipe black paint. The paint will permit the tank to absorb as much of the sun's energy as it can. You will also need to assemble a straightforward plywood box around the water tank. Be sure to insulate the interior of the box with some fiberglass insulation, as this will facilitate eliminating any energy lost within the system.
At this point in time, you would install the painted water tank into the box and attach any of the necessary plumbing to the bottom of it. These are, of course, the pipes which carry the water from your house to the heater. Another set of water pipes will carry the water from the heater back to the houses water distribution system.
Here you have a simple home made solar water tank that is more then capable of providing a single person or perchance a couple with adequate quantities of water.
