Toto Toilets w/ Gmax: are there 2 different flushes (regular & strong?)
I'm looking into getting a drake toilet (from Terry since I'm local), and was wondering if the Drake or the Gmax series for that matter had two flushes you can choose from. I was at a buddy's house last night to check out his remodel (I really went over to check out the drake he had) and he said that if we press the flush lever it will do a regular flush and if you hold down the lever it will to a more powerful flush, but that would use more water.
I lifted the top off and noticed that with just pressing the lever and not holding, the tank went down halfway. If you held the lever, the water went down all the way. I've never seen it advertized or read that there were two different flushes you could choose from. I was hoping if anyone ever heard of this or is my buddy just holding down the lever for no reason. Thanks
two flushes - one doesn't stop
When the toilet is flushed so that the tank half empties, many times (about 50%) it doesn't stop filling. It seems like the flapper doesn't quite go back in place correctly and it leaks around the edges, causing it to continuously fill. A full flush and quick giggle of the handle seems to solve the problem.
Does my flapper need to be replaced or is there an easier fix.
TIA - BTW I am in Minneapolis, MN. The toilet is a Drake, purchased about 4 years ago.
