Can a 7.5uF, 370 VAC run capacitor on my AC blower be replacled with a 7.5uF, 440 VAC capacitor? If I do, will it cause a problem? Thanks.
Printable View
Not a problem. You can go up in rated voltage but not down
Ditto.
The voltage rating on a capacitor (similar to the insulation on a wire) is the max supported before it could arc or short out by jumping between the insulation and the working parts. So, with what you have, you are getting a better rating.
