Culligan Mark 812 Water Conditioner - Time to replace?
Hi,
I just purchased a house with a Culligan Mark 812 Water Conditioner. The conditoner was put in about 13 years ago. It doesn't seem to be doing much to condition the water as soap doesn't lather good and there is a strong iron smell to the water. Also, spots on the glasses, etc.
I have it doing a recharge about 2x per week and there is only 2 of us in the house. I had recently sanitized the brine tank and the salt level is adequate. Any suggestions on troubleshooting this? Could it be the media has reached the end of its useful conditioning life and if so, is that replaceable? I hate to have to replace the system as it is not in the budget right now.
Ron
Culligan Mark 100 soft-minder
Hi
Our softener is about 15 years old on well water. For the most part, it has worked fine. I found if I add one bag of Rust remover to 3 bags of salt there is very little rust buildup in the house and the wife doesn't complain about her hair turning orange.
Now, my problem. A couple months ago I had to replace our well tank. Since then, it seems the softener regenerates but am getting a lot of rust in the house and the slick feeling in the shower is long gone. When the water first came back on, we had some black water in the house for the first few minutes, so I figured the valve was plugged somewhere.
I took off the valve, rinsed it out in the bath tub, pulled everything apart I could find to take out, cleaned everything I could. I had a lot of black pieces in the but when I was done, but nothing big enough that it would seem to plug the entire unit. This seemed to help for about one shower, then back to the same thing.
The salt level does not seem to be dropping, even though I have manually regenerated it multiple times. I have not added salt since the well tank was replaced, I thought maybe the screen in the bottom of the brine tank was plugged so I took it to the car wash and sprayed it with high water pressure, still no better.
The softener is working to some degree because if I bypass the unit, you can see the water turn orange in the house. But it is not working as it should because the toilet, shower and sinks are getting very rusty and there is no slick feeling in the shower.
Should I try clearing the valve again? Is there something or some place I should pay special attention?
Thanks for your time.
Tom
