two yellow post approximately 1" long
Quote:
Originally Posted by
Gary Slusser
That would be an axle and if it is broken off as opposed to just out of its place, then your valve is seriously busted.
and you would need a new module or whole control valve.
Thanks for reply. I don't think the two yellow post are broken but when I lifted the head they fell into the top of the tank. I just didn't see where they go...it appears that they may just sit in the tank by the outlet regulating the water intake/outflow? It doesn't look like they go anywhere in the head...any insight is much appreciated ..thanks. Note, I think the system was cycling correctly found that the brine tank float was shot..styrofoam floats broken and valve not shutting off..this part is on order.
