WM Solenoid Replacement Update
Sorry to post on so late after my initial post last year.
I had an irrigation guy out last fall to replace all of my solenoids (32) at WM's expense. When he came out and saw how my system was wired, he told me that was why I was having so many problems and that he'd seen it before.
His explanation was that the wire to the solenoid (not the common, but the other) should have been 'terminated' at the valve and not connected to the ongoing lead down the line, as the common wire must be. So he clipped the one side after the solenoid on all the valves.
This seemed to have made a signficant difference. The rest of last fall was dry and I ran the system regularly without problems....
However, this spring and early summer have been excessively wet and hence I haven't had to run the system up until now. After the first week or so of use this summer, I have had two solenoids go bad on me, one that stuck with the valve shut, the other with the valve stuck open.
It's too early to tell, still, but this does not make me as comfortable as I was at the end of last season. The guy who replaced my solenoids said to call him back if I had any further problems and left me with several extra solenoids. I replaced them but have not had any success keeping the one solenoid threaded in place, so I think I'll have to have him come back out.
The saga continues....
The thread that won't die!!!
In case no one else is keeping track, this thread has been running since July of 2005 !!!!
