TOTO Aquia III, CST464MF dual flush toilet product review, three and two
http://www.terrylove.com/wc/toto/aquia3_side_pink.jpg
The new Toto Aquia 3, CST464M dual flush toilet product review.
Aquia three, Aquia III
http://www.terrylove.com/wc/toto/aquia3_top.jpg
Pictured with the Toto SS204 softclose seat in Cotton White.
The smaller side of the button is for the small flush, the larger side of the button is for the larger flush.
http://www.terrylove.com/wc/toto/aquia3_top_open.jpg
With the seat lid open.
http://www.terrylove.com/wc/toto/aquia3_back_bowl.jpg
Looking at the back of the bowl. The drain from the bowl fits into an adpapter that comes with the bowl.
Installation instructions for Aquia
Complete Instructions for the Aquia written by Jamie
2 Attachment(s)
Toto Aquia III CST464M toilets rocks/shifts from side to side.
Hello.
We had a plumber install the Toto Aquia III dual flush toilets in all 3 of our bathrooms and they work just fine.
No leaks and they flush just perfectly.
The issue we are having is that all 3 seem to be loose.
They rock from side to side ever so slightly and you can feel it if you sit down and move around slightly on the seat or are trying to stand up off the toilet.
At first we thought it may be loose horizontally mounted bolts on each side of the toilet that hold the toilet in place but those are as tight as they can go and I do not want to tighten any further in case I crack the porcelain.
The toilets sit flush and straight and level on our porcelain tiles so thats not the issue either and the floor is perfectly level also.
Any info would be appreicated.
Thank you
