Drain Line for septic - DIY?
I have recently bought a piece of property on the lake, and want to use it for recreation with my travel trailer.
There was previously a mobile homes on the property that was connected to a septic system.
I have dug around the existing drain line, about 18 inches "up from" the septic tank. It looks like 5 inch PVC. This is right at the clean-out.
I want to cut the "PVC line" in half, abandoning the old pipe, then, install a 45 deg fitting and run up hill to the level spot where my travel trailer is located.
Are the lines PVC? Do I use the same glue that I used to do some presure water work under my house?
When I cut the 5 inch PVC line, will septic leak out?
