decided to just replace the motor
how hard is it?
can it be done from the inside?
where can I get new motor?
can I go bigger or should I go bigger?
Motor Says
DOW-136034 120V 3.4 AMPS
Thanks all
Printable View
how hard is it?
Motor Says
Thanks all
Not hard to install, unless trying to do it in the heat of the day. It can be done from the inside. Be sure to remove power before replacing.
Check out the big box stores, HD and L...s have them look in the construction supply area where the fans are, I would stay with the same size motor.
Grainger for motors
