Is it possible to get a 10 inch elongated super flush toilet, and if so, which brand?
Printable View
There are many that you can get with elongated bowls and 10" rough.
In the Seattle area, I'm bringing in some 10" Toto Drake toilets.
They only need 9-1/4" to install.
CST744EF.10 or CST744SF.10
Comfort height, elongated bowl with either the 1.28 gallon Watersense Eco Flush
or the 1.6 gallon G-Max flush.
http://www.terrylove.com/pdf/cst744ef.10.pdf
Gerber Ultraflush, w/10" tank
Cadet 3 w/10" tank
Toto Vespin, Carlyle, Soiree, Guinevere, w/10" Unifit
http://www.terrylove.com/wc/toto/cst474_side.jpg
Toto Vespin II CST474CEFG with SS114 Softclose seat.
Map rated at 800 grams, Killer!
This bowl was installed on a 13-1/2" rough-in using the 14" Unifit adapter.
The water shutoff can be as close as 5-1/2" to the left of center, unless it's higher off the floor, and then it can be even closer to center.
This shutoff had been replaced with a new 1/4 turn valve with brass nipple through the wall.
Installation was by James Love of Love Plumbing & Remodel 206-949-5683
In some of the older Seattle homes, the old toilets had been wall mounted tank toilets.
Those typically are 14" rough-in and need a flange repair to use standard closet bolt connections at the flange.
Everything is on the truck for that.
The Vespin comes with a standard 12" adapter or you can order a 10" or 14" adapter depending on your rough-in distance.
The Toto's listed, and the A/S have a gulp type flush,
The Gerber has a pressure assist, then sounds a bit differnet.
http://www.terrylove.com/wc/toto/cst744ef.10_rough.jpg
