Wood Stove Hot Water Danger..
A Quote I Found: I DO NOT KNOW THIS PERSON!
"A co-worker of mine put a heat exchanger in his furnace firebox. Without proper controls he quickly made high pressure steam and soon solder joints were failing and the system came apart in what sounded like several small explosions. His solution? Weld the damn thing together the next time. It held together, but it back-fed steam all the way to his artesian well and he had a nice geyser out back. True story."
Scott
In this case the pressure had somewhere to go. Without a place to expand the resulting explosion could cause injury or death.
I am very interested in heating hot water using wood as a fuel source. I want to do this safely and efficiently. What are some general considerations before I even begin to discuss specific ones? I have 2 good engineering schools neary to me, and both do work on alternative energy. I may be contacting them, but I wanted the opinion of you pros first.
The biggest obstacle to adding DHW systems to wood stoves is that EPA emissions certification virtually eliminates the possibility of taking heat directly from the stove. Any DHW collector that robs heat from the combustion process would almost certainly create a dirty burn that would fail the stove. That is why manufacturers of EPA certified wood stoves don't offer DHW collectors as optional accessories. There may be one or two available, but we are aware of none at all.
TIA,
Molo
Wood burning stoves and insurance companies
Another thing to think about......
I had a very cheap wood burning stove in my old house in the basement, it could pretty much heat the whole place
well ...but my home-owners insurance had a hissey fit
when they learned of it......
if he is still doing this or you are thinking of rigging up some sort of steam boiler---wood burning stove.....
you will probably not be insured when the unit burns down
your house or blows out a side wall or roof...
they will worm out of covering the damages...
becasue their is no UL or Antsi lable on that rigged up
boiler you created....
stuff like this was done a long time ago with the original manual water heaters called "side arms" in 1880'
...ocasionally someone would forget how to operate the unit they and it would cause a steam explosioin.....
many people are trying to figure out a better mouse trap right now ........for home heating..and you can
find their creations alll over the internet for sale...some good and some bad.....
if I could talk my wife into a good wood burning stove in our downstairs laundry room we could easily heat our
house very well with that alone.....
Why would youwant to waste the time???
[quote=molo;105413]THIS IS AN OPEN SYSTEM, I'm talking about placing a metal pot on the stove with 5-10 gallons of water while I'm at home. IT WILL NOT EVEN HAVE A LID. Worst case scenario, it will evaporate out.
Also, the first post isn't somebody I know, it is a quote from a site with extensive warnings about designing and building unsafe systems.
Yes, I see that trying to add hot water to the tank would be tough when the tank is full. Does anyone have any suggestions for how this could be done?
I did not read your second post but why would you want to waste the time trying to heat up 5 gallons of water....??.
If you are really serious about trying to capture some hot water from your wood burning stove.....
it might be easier to run a copper coil around the chimmney of the stove fed from the bottom of the heater and going back into the heater at the top....
it could be a passive thing without any pumps to move the water, I would guess that
it would draw natrally as the water heats it rises .......
you would probably collect some heat by doing that.
or you could add a amall pump to move the water through the coil...
you wont save anything....
my best suggestion is to
keep chopping that wood
how to get the hot water into your tank
Well first of all, i see no problem with putting pots on top of your wood stove. I have been doing this, and as mentioned its an open system, so the highest temperature that can be reached is boiling. I live in a dry area, so i always had a pot, to increase the humidity. Then i started putting the hot water into the bath to preheat the tub, and a little water [3 gallons]. Of course thats not enough water, so i now have 3 pots on the wood stove equating to around 7 gallons. What the heck throw the teapot on there and make tea for free. Of course the problem with this is that yes it is work, and of course you can burn yourself transporting the hot water. But i live at 6000 ft, and water boils here at only 190f. Reach in boiling water and pull out an egg...
I don't agree that 5 or ten gallons of hot water is nothing, but then again i am one person, so it would get logistically hard for a family of 4 to heat 30 gallons or so on top of the wood stove. Using this system i have already had 2 baths today. You just might need to change your habits a bit. Take the hot water and pour it into your washing machine, or put it next to your sink to wash dishes, or fill the pot to cook your pasta with hot water. I ran a pipe up next to the wood stove, with a valve, and then a flexible line, so i can fill the pots easier.
So yes this takes time, and i guess thats work.
But yes with increasing fuel prices, why not reduce your usage which reduces your costs. Also reduces our dependence on foreign oil, and reduces profits for the oil companies who have been making record profits.
So anyway back to your question. I don't see an easy way to put the actual water into your hot water heater. All sorts of problems can arise such a burning out the element because the elec is on and there is no water in the tank.
A question: Is your hot water tank higher or lower than your wood stove?
What I am thinking of doing is installing an open system tank above the wood stove. Then running coils around the flue pipe, and possible some kind of heat exchanger on the side or back of the stove. As long as the pipes are always heading upwards, the water will naturally convect up to the tank. This line should go into the top of the tank, not the very top, but say 1/4 down. Then the tank needs an overflow also. But of course this is a separate system. But i used a system like this with a self built solar collector, and it heater 20 gallons, and didn't need to turn on the hot water heater all summer.
Ok, so i was thinking for your scenario...maybe buy a rheem 80 or 120 gallon solar tank. The loop collecting heat from the wood stove will travel to the copper coils in the bottom of the tank transferring the heat to the pressurized water in your house system. These tanks have an electric element at the top, so if needed it will automatically add heat to keep your water coming out of the tap at a constant temperature. Of course you would need a pump, and an expansion tank, temperature sensor, other stuff, and of course for any type of pressurized system, and probably a good idea for any heat exchanger with a wood stove I think an overpressure relief valve that was plumbed outside the house "wood" be mandatory. [REDUCE THE EXPLOSION FACTOR]
Another idea is maybe some type of drain back system like they use for solar also...no heat at the stove, then the pump is off and the water drains back down to the tank...of course the exchanger has to be designed for the fluid to flow uninterrupted...I am just learning this, also maybe a vacuum release valve...
cool thread
