Need for a very quiet toilet
Hi Terry:
I desperately need your help and advice. I'm a 75 year old handicapped retired musician with critical hearing. Even the slightest of sounds drive me batty! I live in a large elegant high rise apartment building in Rochester, NY, and I believe the building was constructed in the 1970's.
Here's the problem: the sound from the flushing toilet in the apartment bathroom above me sounds like NIAGRA FALLS! (I can even hear the man urinate, too!) It awakens me several times each night when the occupants flush their toilet.
Our maintenance man, who claims to be a plumber by trade, says there's NO such thing as a quiet toilet available for installation. I find that hard to believe in this day and age. He tried to put some kind of boarding on parts of my bathroom ceiling, hoping to mute the sounds, but he used one of those nail air guns and shot about 40 metal pins right up into the concrete ceiling. Metal in concrete acts like a soundboard, and the sound waves are now carried directly into my bathroom AND bedroom....it's actually WORSE than before.
I'd appreciate any suggestions you could make, and I'll share them with the management of the building. My body is exhausted by not being able to get a good night's sleep.
Thanks so much, Terry, for taking the time to help out this poor old frustrated guy.
Good luck with all your endeavors. Have a GR8 day.
Regards.
Ken D
Understanding the correct noise problem is key to selecting the correct solution
I know this thread is old but for the sake of new people trying to find solutions to toilet noise
problems, their are two types of noises to be concerned with in buildings, each has a different solution approach.
The first is air borne sound transmission, this is the sound generated and transmitted through the air, such
as is the case of under insulated floors and walls, where you can hear more or less everything going on in the next suite, you can literally hear the toilet beside you or above you, this solution calls for extra insulation in walls,ceilings, with sound channel if possible etc.
The second sound is impact sound transmission in the case where someone is hammering on the wall or floor, or toilet noises like when someone is urinating into a toilet and the sound is transmitting by impact, water to bowl, bowl to toilet, toilet to tile floor, tile floor to concrete, concrete to air and to your suite. This type of sound has to be decoupled to make a difference (Daves' solution above which is great), the toilet needs a gasket of some sort between the toilet and the floor.
In the case of hearing flushing water noise sounds like water rushing through the pipes, this sound is more likely exposed drainage pipes from above that are running in your bulk head or wall that have not been insulated probably. This is solved by sound transmission techniques, insulating the pipes, better sound proofing in the ceiling or walls etc.
If you hear screaming sounds when the water is turned on from a tap(water supply lines) this is where the plumber has strapped the water supply lines incorrectly to the framing causing and amplifying the sound, it needs to be decoupled, with insulating connectors. If its just water sound though the pipes then its more
a sound insulating problem.
So understanding the nature of the noise is important in helping to find the correct solution that brought you to this post and driving you nuts.
