Hey guys,
Need some advice. I've got a 1.5" copper drain line that come up out of the ground and has a brass 90 elbow on top that enters a p-trap that goes into the bottom of the laundry tub.
What I'd ideally would like to do is cut the copper and put in an additional out area so I can run the washer right into it as opposed to into the laundry tub.
Here is a drawing to illustrate.
Will this work and if not what is the best option?
Also what is the best way to convert from copper to PVC if the plumbing has to float in mid air?
Tom
