Oatey No-Calk fiberglass shower base drain
Hello to all! I am installing a new Swanstone shower base into a new master bathroom. I have no access to the drain from underneath so I am using a "Oatey ABS no-Calk Fiberglass showerbase drain". I have read a few OLD post about placing the no-calk fitting onto the 2" ABS drain and just tightening it "enough" to compress the rubber seal around the pipe. The plumber left me about 4" of 2" abs coming out of the floor. How close should I trim the ABS to the floor to install the shower pan and base drain? Should I use silicone on the compression rings? After I tighten it, should I apply silicone to the upper side of the compression rings? The only way I will be able to tell if it leaks is if the plaster starts getting wet in the kitchen below...
As usual, thank you in advance. This sight is most helpful to us rookies!!!
Rich
