Indiana is a good test zone
honestly ,, it really does not matter where you
put one in... the btu cost can be factored in within
a pretty close range....
I am testing for cost and efficinecy differences with my trusty gas meter...
then I am gonna try to figure out how many years it will take before that 2600 invenstmet will pay off.......
I have Delta 1500 pressure balanced valves in the home
and the high maintaince wife.....
and other little factors like ease of operatioin
ect, ect... how long it takes to get hot water
60 feet away....
Of course this state is ground zero for nasty water,
but My CLACK water conditioner should make
the water at alomst 0 hardness....
and dont forget the cold water in the winter time....
about 48 degrees and lower.....
If it can work here without too much in-convienance,
and it acutally saves money and you have an eventual payback.....
then its good about anywhere.....
SO it begins....Sept 16, 07
http://upload.wikimedia.org/wikipedi...d_Serling1.jpg
Submitted for your viewing approval ....and consideration....
one over-weight plumber with nothing else better to do today
while being stuck baby- sitting two 6 year old girls untill 7 pm tonight
on a beautiful Sunday morning in indianapois indiana....
one new gas meter bought off e-b// for 89.00.
the meter is pre-tested and pre-set at 6.2 btus ....
One 2 year old 75 gallon gas Bradford White heater already hot
and the unit is covered by a blanket.......
now how many cubic feet of gas will it take to heat the water
for one week to two months.....????
inquireing minds want to know... sept 16,, 2007
(I dont get out very much....)
Now after about 4 months....I plan to switch to a tankless water
heater Probably a TAKAGI or Rheem just to see how it performs in
basically the same conditions.......
started experiment with 6.6 btu at high noon.
http://onsmartpages.com/weilhammerpl...0_DSC03577.JPG http://onsmartpages.com/weilhammerpl...0_DSC03583.JPG
I am curious as to how much this thing will spin in an hour.....
how much the piolit light actually uses per day
as you can see it goes by 10ths of a btu......
probably wont come on today to re-heat till tonight.......
Had a lot of time on my hands today
Grumpy, read the posts closer....
I dont think I can make it any simpler...
now its all just figuring the math on the btus
Yes....I had a lot of time on my hands today...
baby sitting 2 ..6 year old girls...
that was pretty dull , but I took them for a walk to
the local store down a few blocks for candy ...your basic parenting
from 12 till 6 with not much else to do....
did a little boookwork, faxed some bills ect.....
anyway.....the meter is in the pic.... you can see
at what point it started reading my gas to only
the 75 gallon 75,000btu brad white heater....
at 6.6
you can see my laundry room..the water heater and
how I installed the meter on the floor
and nothing else is on that 3/4 line
with only the piolit light going it went from 6.6
to 8.4 at from 12 to 6 this evening.....
I am trying to keep this simple and it seems fairley easy
so once I figure out the math its no big deal to
know what a 75 gal heater average costs are per month.
bob newhart seems to have a handle on that already for me.
