osx-addict
Software Engineer
Hi all..
I've got 3 of these Hunter valves that I installed about a year and a half ago in a rental property we've got. Apparently one of them has malfunctioned OR something I suppose could be clogging the pipe? I can not turn on the valve manually either electrically or by turning the solenoid/bleeder screw.. Nothing happens -- no obvious water movement. The other two valves on the manifold are working fine -- this non-working one is the last one in the manifold that is furthest away from the incoming water source -- not sure if that matters. Do I need to rip the manifold apart or is there something else I should check first? Thanks! I've never had a valve behave like this before..
