Getting a snake through a p-trap?
pedietz
My pedestal sink is so close to the wall that I can't get a wrench on the clean-out on the bottom of the trap. Any suggestions on getting a snake through the trap? The drain appears to be blocked about 4 - 6' away from the sink, for what that is worth.
Plumber1
Florida
I use a small cable in a tapered can with an offset handle and just wind it through the trap. It's stiff enough to get through the trap and It makes 90o turns quite easily and you may not be any more than 5 feet to a stack.
Verdeboy
This might be a good situation to use one of those drain cleaning bladders.
pedietz
Clarification?
plumber1 said:
You use it, I sure won't....
Why no drain cleaning bladder? Does it matter if the drains are cast iron, not PVC?
Dunbar Plumbing
www.KoldBreeze.com
They are no good if there is a tee in that line serviing as a vent before the clog.
I've seen best results with those on floor drains where the piping is collapsed and no cable will pass through.
Some swear by those fast action air movers that drano sell. The commercial alone is enough to gross even me out.:eek:
If you use a drain bladder it can force compression joints to blow apart/cause them to leak after the drain is open.
