Older Moen Faucet
xrionx
I live in an apartment, and my landlord is footing the bill for repairs, but I want to keep this as simple as possible.
So the problem I have is when I am in the shower I get the classic extreme hot to extreme cold due to the water pressure fluctuating in the building. The faucet is a Moen push/pull type. My question is can I change the cartridge to an anti-scald type, or does that require changing the entire fixture. I do not have rear access, so in order to change out the entire fixture that would require having to rip out the tile, not something I want to do in a rental unit.
Thank you for any help/advice, and let me know if I need to give more information.
You would either replace the entire valve, or use a balancer on the pipes leading to the faucet.
Either way, you would need some access.
They do make remodel plates that help on this.
Moen part 1920
attachment.php
xrionx
So they don't make a replacement cartridge that will provide anti-scald? Too bad, i was hoping to make this a simple repair. Thank you though!
Moen
Rmove the trim plate and see if there is a large slotted cap/plug on the right side of the valve. Depending on what kind of building the apartment is in, it could be a Moentrol with a bad balancing spool.
xrionx
Do you know of any sites that have a picture of what that might look like? Im the meantime I'll take a picture and post it and see what people think. Thanks again for your help.
xrionx
Nevermind, I found pictures of what you are talking about. I will look at it when I get home tonight. If I do have a Moentrol are all the balancing spools the same? If not, how do I figure what model I have?
Redwood
Easy to get also... Just call 1-800-BUY-MOEN and they will have it at your doorstep next day air for free.
Redwood
I guess the customers that I have had get their free parts all opted to pay extra to has instant gratification by having the next day air... I knew I should have charged them more... LOL
