Moen Toilet Levers
bielen
New Jersey
Does anyone know if the Moen Toilet levers, specifically the Waterhill, will fit the Toto Soiree. It says it will work with most front-mount toilets, but there's no way to confirm when calling Moen or Toto.
Looking inside the tank of the Toto Soiree
For max reliability, the end of the arm of the lever must be above the flapper, and nearly centered so it can pull almost straight up. Hard to say if it can be bent to match up without seeing it in person or a really god photo. The hole through the tank is probably about the same, but that's not an absolute (but you can measure the Toto's hole and compare to the drawing).
