sump pump/floor drain question
moisheh
Mexico and Canada
We have bought a house in the country. Although code calls for a sump pump, inspection is very lack. There is no sump pump nor pit. There is a floor drain/catch basin. I can see the weeping tiles( corrugated tube) where they enter this drain. I can also see another tube in the center that must go to the septic tank. It would seem to me that sending clean water to the septic system is bad design. There is no evidence of there being any back up problems. The whole area is built on a gravel ridge and has good drainage. I know the lack of a sump pump should be corrected. What is the best way of doing this without breaking up a lot of floor? Make a pit close to the drain and extend the weeping tiles to the pit? Convert the existing floor drain to a sump pit? Please excuse my ignorance on this subject. I understand city plumbing but this is new to me!
Moisheh
Leejosepho
DIY scratch-pad engineer
www.nonameyet.org
Sending that water out to a septic tank would not necessarily be a bad design, but I would nevertheless suspect it goes somewhere else on your gravel ridge. If you have easy access to see inside your septic tank, take a look while using a hose to pump water into your floor drain. If you do not see that steady flow coming into your tank and your floor drain does not overflow, I would say you have a drainage system that works fine just as it is.
moisheh
Mexico and Canada
Thank you for the replies. It may be that there is no problem. I guess the lack of a sump pump had me worried. I will check to see where the water in the catch basin goes.
Moisheh
