Toto One-Piece skirted regular height
engra
I'm looking to replace a 1994 toilet with terrible bowl wash.
I just did an ultramax 1.6 in our master bath, but I have two little kids, one of which is a 4 yr old boy. So to help with clean up all around the toilet, we would love to get a skirted model. I know about the Soiree and Guinevere but they are the Universal height, and with my 5'4" wife and kids, the standard 14 5/8" is much better for us. This requirement seems to have eliminated all of the newer models with double cyclone. Too bad, I really wanted that feature.
I was leaning Carlyle, but our water supply is the standard 5.5" from the toilet centerline and 6.5" high, with the valve protruding 3" from the wall.
So here are our requirements.
Skirted
Shorter standard height
Something that fits our water supply requirements
I thought I read somewhere there was a close to the wall angled shut off valve, would that work with the Carlyle? Or would a 10" unifit help?
Are there any other Totos I'm overlooking?
An Aquia II CST416M would work with your shutoff
Bowl is 15-1/8" high, skirted elongated
Or use the MS874114SG Carlyle
Bowl is 15-1/8" high, skirted elongated CEFIONTECT
Your options are:
Solder a 90 el and 2" of copper pipe with shutoff,
This is what we do most of the time. It takes very little space, and put the heat right on the fitting.
Use the Dahl valve made for Toto, they are 1-1/4" from the wall. Sometimes you can sink it into the wall some.
attachment.php
Use the 10" Unifit to move the bowl out 2" more inches.
engra
Terry, you are the man! I love your website, thanks for taking the time to educate the public. It's great that you personally post all the time.
I thought the Aquias only came in two pieces. Is this particular model a one-piece? I'll go this route if it's a one piece, but I wonder if the flush button on top of the tank will be a problem for my 3 and 4 yr old.
I'm an engineer, but not skilled enough to try the soldering so close to the wall. Unless the aquia is a one piece, I think I'll go with Dahl valve and 10" unifit to make sure I have enough room. With my boy's aim I may need the couple of extra inches to clean behind the toilet anyway. :)
On another topic, why is Toto going with the Universal height? I once read the best pooping (very techincal, I know) position is actually squating on the ground. That's how humans were designed. This new height will probably generate a lot more cases of hemorroids!
The Aquia is a two piece, I forgot about that requirement.
If you turn the heat down, it's not so hard when soldering. Just keep your water bottle handy, and wet the drywall first.
You could even use something like a soldering iron if it could heat the fitting good enough.
Low bowls for evacuation, yeah I've head of that.
Many countries have a pan on the ground for squatting.
In many public restrooms, if you think you are seeing footprints on the seat, you are.
