ACEschborn
Hello All!
I am looking to bring my basement fixtures' drain plumbing up to snuff. Long story short, things are not correct (happy to explain as needed). I want to make sure everything is safe (think: air gaps, p-traps, backup) and hopefully (but not necessarily) up to code (2003 IPC). The fixtures are a water softener, acid neutralizer, clothes washer, and reverse osmosis. The basement is not, and never will be finished.
I’ve attached current and proposed drawings. There is one update to the proposed drawing that I did not re-draw: The proper double fitting should be a double fixture tee not a double san-tee.
Questions/comments:
Thanks in advance for your help!
-ace
Questions/comments:
- Air Gaps
- On one of the 18†standpipes I’m planning to use THIS air gap, which will receive the reverse osmosis and water softener drainage
- On the other 18†standpipe I’m planning to use THIS air gap, which will receive the acid neutralizer and clothes washer
- Do these two air gaps look okay? - If I use 18†of standpipe, I will probably be up into the space between the joists; is this okay?
- This would still be less than the max height (96â€) that the clothes washer can pump per the owner’s manual - Do all of the fittings, pipe sizes, and lengths look okay?
- Can 2" pipe handle an acid neutralizer and washing machine? They will likely never run at the same time. - Do I understand correctly that the trap arm for the 2†standpipes must be greater than 4†(and less than some other number?)?
- Do I need vents for the new 2†standpipes and traps? (this would be very difficult unless I used an AAP/tudor)
- Am I missing anything? Anything else to consider?
- Shouldn't the horizontal 4x3" san-tee actually be a wye + 45 or combination wye?
-ace
