sprusgoose
I am about to get started on a bathroom reno that I put on hold from last year and need to re-jig the layout a bit to fit in a shower. The dimensions of the bathroom are 63"x69". Currently the back of the toilet sits against the 69" wall and it will need to be turned 90 degrees to give me clearance on the 63" wall for a 32"x32" shower. Unfortunately, there is a joist running at exactly 15" on center from the wall when the toilet is turned 90 degrees, and as I have no wiggle room in order to get the shower in with proper clearance for the toilet, I need some advice on what the best solution to the problem is.
I currently have 3 1/4" from the center of the toilet drain (3" ABS) to the joist in question (12" from center to the wall). The way I see it, I can either:
1) shift the toilet drain over 1", and then get an offset toilet flange to make up the last 2", or,
2)I can header the joists and move the toilet drain over the full 3".
I'd prefer to do option 2 as I have a drop ceiling in the room below (a bit of drywall around the bulkhead the currently houses the toilet drain off the main stack), however, previous to when I bought the house, someone has run all sorts of electrical through and under the joists that would have to be pulled from the panel and re-routed as it currently interferes with where I'd have to place headers. Is option 1 acceptable? It would require that my toilet drain rough-in be 2-2 1/4" from the joist...is this too tight (any code for this??)? Any help is appreciated!
