TrapperMark
Pump - Franklin 1/2 hp 2 wire submersable (installed 1 week ago)
Switch - Franklin D Switch (new last week as well) 30/50 psi cutoff's
Pump Depth 100ft
Well Depth 120ft
Pressure Tank - Redline 40 gallon
Pump Wire changed 5 yrs ago
Water Line - age unknown
O.k, I have looked over the posts trying to find a solution to my problem but mine seems to have a twist to it..
One month ago I suddenly lost water pressure, checked gauge it was zero and the switch was tripped open. Reset switchs and had instant recharge of line. Then the low pressure problem would happen when we would do a LARGE load of laundry so I thought we were low on water but the fuses would not burn out. Suddenly last week everything went dead along with the pump fuses blown. I figured out it was the pump and replaced the pump and while i was at it i replaced the switchs and everything worked as it should. When i changed the pump I observed we had lots of water. Yesterday, we lost pressure, switch was tripped open and the fuses were blown. I replaced the fuses and engaged the switch to power up the pump. The pump works trying to build up pressure to 50 psi but it cannot do it. I have tripped the switch and observed my pressure gauge and there is no drop in pressure and from that I am figuring my check valve located below my tank is working properly (?). To not overload the pump I kept it "off" all night. I am thinking that the reason my original pump went was because it was going non stop and this pump tripped yesterday because of the same thing. WHAT is the cause of the pump not achieving the correct pressure ?? When I pulled the system last week the water line looked fine and I inspected all the pwr wires closely looking for breaks but found none. I hope all this is not too confusing in my explanation... Many thanks
Pump Depth 100ft
Well Depth 120ft
