Need advice on fixing Delta 600 shower/tub valve - dripping water
bang0r
San Francisco
I'd like to seek advices from this forum on how to fix a leaking shower/tub valve.
This valve came with the house when we moved in in the 1990/2000; the plate indicates it is Delta, but I'm not sure if that was for the handle conversion kit or indeed same for the valve. Attached are pictures I took to expose the valve. Are there any cartridge that one can replace to fix this kind of valve.
Please advice. Thank you.
bang0r
San Francisco
Thank you very much for the information.
I just like to update the forum that both Lowes and Home Depot carries the Delta 600 replacement parts I needed.
I settled for the Delta RP4993 seats & spring, the RP70 steel ball and the rubber washer.
I also come across this Delta 600 repair tutorial video at http://diyplumbingadvice.com/faucets/deltashower.shtml which caution about turning the dome too forcefully could result in breaking the 3 pipes in the valves. In my case, the dome came off quite easily.
No more dripping tub facet! Rejoice!
