single, moen; not getting hot water!!! plz help
maor
Few months ago a handyman remodel the upatairs bathroom, I tried to shower but didnt get hot water...!!!!any suggestions will be appreciated!!
Redwood
Under the handle is a hot limit stop it probably needs to be adjusted properly.
Do you know what the model # is?
maor
Thanks for replying!! and no i dont know the model#...! i took it apart ..... and it does have some plastic stopppers but even when i turn the water on with out them it still comes out cold ... i only get a little warm after i pass the 180 degree turn but only get a tritkle of water!!Any suggestions !!!
Sounds like one of two things: the pressure balance spool valve is stuck, or there is some debris caught in the hot inlet. If there's an in-line stop valve, it could be closed. How old is the house? Could there be some galvanized pipes in there that are all clogged up with rust?
maor
im not sure around 50s and ill check for the galvanize pipe!!!\
