pcanonge
Shower Pan, How to??
Hi,
I'm more comfortable with a PC then a shower pan. My fibreglass shower pan seems to be leaking at the drain fittings. I have a concrete foundation and need advice to fix the leak. Water is seeping out from under the pan and soaking the base boards. Can I replace the drain fittings? Or should I plan to tear it out and replace. ( with tile!!!!) It's quite gross since I now have tiny little bugs that crawl out from under the trim and base boards.
Any advice will be welcome....
Patrick
Hi,
Patrick
