kevinkay
Do they make a fitting that would allow the tub drain on one side of the joist (a hole then trough the joists) and the overflow on the otherside.
My Joists are TJ's so I can't notch them, hole has to be closer to center so the drian fitting "L" (tub shoe?) needs to be longer at the top before it turns.
IS there such a fitting, is it allowed?
OR, is is allowed to "T" the drain and overflow UNDER the joist?
Kevin
Kevin
