corian shower floor
gildedgrit
las Vegas, nv
I am about to have a shower redone in corian. I have been told to use the original tile for the floor. Can I use corian? Or is there a better solution?
Thank you
Not sure exactly what you're asking. A shower pan (the floor) needs to be sloped to the drain, and needs a lip so Corian walls could be applied to make the whole thing waterproof. A typical tiled shower has a liner that goes at least a few inches above the top of the curb. Anything less, and you are at risk for failure.
If you have a Corian pan, I'd be surprised if it could accept tile.
For shower construction help, you may want to check out www.johnbridge.com.
corian
Corian is too rigid to be bent to make a one piece sloping floor. It is usually too narrow to make a one piece floor also.Cultured marble will deform to make a depressed shower base, but not Corian.
