canyonblue77
I'm a diy'er that bit off a little more than I can chew, but I'm stubborn and intend to make it happen.
The attached picture is a very simple version of what I'm in the middle of with plumbing my bathroom reno.
Basically I want to know if the additional vent stack in green would be required or is the current 4" stack enough venting and close enough?
Is the "stacked" connection of the drain pipes in blue acceptable? (I intend to use wyes instead of tees although I don't believe it's required)
Is the fact that the vent technically begins below the height of any of the traps an issue?
If the green vent would be required, is it ok that all 3 fixtures would be using the same vent.
And last question... do I have too many bends in my proposed vent stack? (Would be 6 45 degree turns and 1 90 degree turn) It will end up passing through 2 stories and have a developed length of nearly 50 feet.
