Broken bolt on cast iron toilet flange
BackedUp
Oregon
Hi all, I ran across this forum when researching new toilets and ran across it again when searching for how to remove a rusted/broken toilet flange closet bolt, as seen in the attachment. The right one crumbled while removing the nut, even though it took very little force. The left one doesn't look a whole lot better. I read several threads such as these that indicate I should have a t-slot to slide the old bolts out of, but I don't see anything obvious.
https://terrylove.com/forums/showthread.php?47977-Broken-Flange-bolt-Not-sure-how-to-proceed
https://terrylove.com/forums/showthread.php?50503-Cast-iron-toilet-flange-replacement
I'm guessing my bolts are threaded into the flange? I can just barely slide a paint scraper under the flange where the bolts are, and I don't detect a nut on either. If they are threaded in, would they be regular or reverse threaded? Or is this even in the DIY realm?
That is lead bent over. What you have are screws into the wood floor.
You can eithe pick up new screws for that, or use a "repair ring" over the lead to hold new closet bots.
BackedUp
Oregon
Thanks for the quick reply! How would I remove the screws exactly? That's definitely the best option if it's doable. I don't see or feel any slots on the top of the unbroken one. Is it just a matter of gripping it with channel locks and turning counter-clockwise?
How would the repair ring work as far as lining up with the existing bolts and still having slots in the right spot for the toilet? It seems like they would end up being in the same place.
WJcandee
Wise One
New York, NY
You're not envisioning what you have. Forget about slots. Right now, there aren't any. You have lead bent over a metal ring. The installer put screws through the ring and directly into the wooden subfloor below. Those screws provide a way to secure the toilet directly to the subfloor. No slots, no sliding t-shaped upside-down closet bolts pulling up on the flange. Screws. Directly into the floor. Follow?
If you want to try to remove the old screws and replace them, your channel locks might be one way, for sure. Others may have better suggestions than this. Given how they look, I wouldn't be surprised however if the screw snaps off in the hole.
If you use the repair ring, you would cut off the old screws, flush with the flange, and secure the repair ring to the subfloor with screws in those outer holes. Its only purpose is to give you a place to put the t-shaped upside-down closet bolts and secure the toilet to the floor (i.e. to the ring). Secure ring to floor; secure toilet to ring.
The wax ring, on the other hand, is a standard diameter and that diameter will fit INSIDE the repair ring, so it is sealing to the original flange. Make sense?
And do yourself a favor: get a set of closet bolts that has two washers and two nuts. Put the bolt in the slot, and secure it to the repair ring using the first nut and washer, then mount the toilet and use the second nut and washer to secure the toilet. That way, the closet bolt will stand up nice and straight, right where you put it, and the bolts won't spin in the flange when you try to remove the toilet years hence. (The shape of the closet bolt should prevent this, but years of decay can yield this result.)
When you mount the toilet, put the wax on the floor, not on the toilet, regardless of what the directions say. That way, it's right where you want it when you put the toilet straight down on the wax.
BackedUp
Oregon
Thanks, that explanation helps a bundle. I'll try removing the screws in the morning. Worst case scenario, they snap off and I'm right back to where I would be with the repair ring, needing to cut them off flush anyway.
Is the lead-over-metal a common method of installing flanges in older houses? I didn't run across that when looking for solutions, but I also wasn't searching for those terms. All of the explanations I found referred to t-slot type setups.
BackedUp
Oregon
No luck removing the screws, so I guess I'll have to cut them off. I picked up two repair rings and a riser ring at Ace to try out, but none of them extend beyond the outside edge of the current flange. They didn't have anything that looks like Terry's photo. Should I try drilling into the lead as a mounting point or keep looking for different options?
You could buy some 'hanger' bolts, which have a wood screw on one end, and the standard screw thread on the other. After removing the old ones, just screw those in (you put a couple of nuts on the top end, and use that like the head of a bolt to screw it into the floor - two nuts, tightened together won't jam tight at the end of the threads if you only used one, and let you take them off after installation). It would be best if you could find them in brass or SS, but I do not know if they make them in other than plated steel, which will likely rust eventually.
BackedUp
Oregon
I saw those hanger bolts at the store and thought they'd be perfect if only I could remove the old ones intact! The ones I saw were brass. Good thinking on the back to back nuts, I'll give that a try.
Gary Swart
Yakima, WA
I would suggest you try Vise Grip pliers to remove the bolts. Channel Locks are great for many things, but you need a very tight grip on these bolts that is very hard to get with Channel Locks.
BackedUp
Oregon
I had the same thought an hour ago, so I sprayed the broken bolt with some WD-40 and let it soak while running some errands. No luck so far with the vise grips, though. That thing is probably fused in there from years of corrosion. However, that could work to my advantage if cutting it off. That might then be as good as a solid chunk of metal to anchor a new bolt into.
WJcandee
Wise One
New York, NY
Ace sucks for plumbing stuff, so forget it.
No you shouldn't drill into the lead. When someone like Terry or HJ suggests what to do, they're telling you how to do it right. You can't half-ass this or you're going to screw it up. Take the time to get the right part, put it in right, and you will be able to forget about this for the next 20 years. Half-ass it, and you're going to end up remembering this week for a long time.
and here: http://www.lowes.com/pd_22062-943-2...g&pl=1&currentURL=?Ntt=repair+ring&facetInfo=
And here: http://www.homedepot.com/p/Superior...Replacement-Ring-21015/202538331#.UVIJghz5mSo
Or go to your local plumbing supply house, where the pros go (look it up in the yellow pages), and take a picture of what Terry showed you. They'll have one, probably a good one.
Keep us abreast of your progress. We're eager to help.
You seem to have missed that Terry said just put in new screws OR use a repair ring...
WJcandee
Wise One
New York, NY
No...I meant that rather than try to attach a different kind of repair ring by screwing through the lead, he should go get the kind Terry recommended and secure the thing to the floor outside of the lead. It's not like that kind of ring is hard to find, except, apparently, at his local Ace. Why make four penetrations in the lead when you can secure it to the floor directly and in more places with the other kind of ring? Certainly, removing the old screws and putting in new ones is an option, but one that seems to be less-than-viable the more he tries it.
Unless it's a concrete slab, getting the bolts out shouldn't be all that hard. As long as the lead is intact, that's probably the best thing. A repair ring introduces another joint that needs to be sealed (not that hard, but still), otherwise it can leak.
WJcandee
Wise One
New York, NY
Actually, Jim, if you look at the dimensions of the ring that Terry suggested, it doesn't. All it does is provide a place to insert closet bolts. The actual seal -- the actual wax ring -- is going to sit inside that ring and seal directly to the existing flange.
BackedUp
Oregon
Don't fight about it on my behalf, guys. I appreciate all the helpful tips, even if some needed clarification. :)
I struck out on finding the desired repair ring at Lowe's, as well. That's always my first choice, but Ace is much closer. Rather than drive around town trying Home Depot, George Morlan, etc., I went with one of the partial repair rings. It's about a third of the full ring, designed for patching broken pieces of the flange. I cut off the bad bolt and secured the partial ring through the lead and through the mortar into the sub-floor. I couldn't follow the advice of a double nut to hold the new bolt in place, as there wasn't enough clearance for it under the toilet.
And yeah, the wax ring fits entirely inside the bolts, give or take a fraction of an inch, so no extra sealing is needed.
All in all, I think this will work, but it's definitely jimmy-rigged. Next time I have to do a toilet replacement (hopefully a long time down the road!), it'll probably require hiring a plumber to cut the old flange out and re-do it properly.
WJcandee
Wise One
New York, NY
Don't worry, we're not fighting. Maybe I came across as more bossy than usual and Jim was trying to let me know that. I respect him immensely, so it's a privilege to reorient him in the one time out of 50 that I know something he doesn't.
Anyway, glad it worked out and happy to help.
PS It's extremely rare, although possible, that you wouldn't have clearance for that nut on the flange. Appearances can be a bit deceiving. But if you dry-fit the toilet and it bumped with the nut, that's pretty conclusive. Hundreds of thousands of toilets are installed every year without that double-nut, but it's a good additional step when it fits.
BackedUp
Oregon
Good. :)
I did dry fit the toilet and the right side was sitting on the nut and raised a quarter inch or more off the floor. Don't forget, my flange is raised a bit and I had to lift it more to get the t-bolt under the repair ring. Plus, the new toilet is a very compact American Standard dual flush unit that has a much smaller profile than the Kohler pressure assist it's replacing. I had to work pretty hard to seat it all the way down on a standard thickness wax ring. There's very little clearance there.
Gary Swart
Yakima, WA
FWIW, WD-40 is not a penetrating oil. One of the best penetrating oils is PB Blaster. However, the screw is not rusted into the wood. It's just tight. Doubt that penetrating oil will help much.
