My toilet began making a banging noise when shutting off, I noticed the ball type float valve would get nearly full, then slam shut, so I replaced it with a fluidmaster 400a. This one does the same thing. Is there a unit that will not do this? I cannot shut my water valve down because it sounds like a jackhammer when I do. Its either all the way on, or all the way off. My pipes are as secure as they can be so far as I can see from the attic. I will probably have my plumber install a water hammer arrester in the attic, but im not tearing my walls out to do it. Is there a valve that will prevent this water hammer or at least not make it sound like my pipes are about to explode from my wall?
