Hello,
I am new to the forum but have found it extremely helpful in posts I have reviewed in the past. We recently purchased an 1850s farmhouse that has a gas storage water heater in the basement and a gas tankless unit on the second floor serving a single bathroom. There are two because the way the house was built there was very limited space to run plumbing to the second floor, and there is no single vent stack running through the house. The tankless unit has a single stack from the second floor to the roof.
Here is my challenge. The basement storage unit does not vent properly as it runs out the basement under a deck off the house. I know this is an issue and I want to remedy it. The problem is that I cannot properly vent any gas unit from the basement (both standard or condensing units) and I do not want to go to electric since the farm has oil/gas well for free energy. Even going with a high efficiency unit that can direct vent poses challenges as the house has decking all around it, and running a stack up the side of the house would be extremely challenging and costly I would imagine.
One thought I had was to use the tankless unit on the second floor to serve the entire house as I do have a spare 3/4 line running between the basement and the second floor to connect back to the basement lines. If the unit is too small (currently 6 gpm) then I could upgrade this unit to a larger unit that could properly vent out the roof and serve the whole house.
Doing the math calculations for load, if I used a single tankless unit to serve the entire house, 6.5 might be pushing it but 8-9 gpm would be plenty.
Does anyone see any challenges with this solution?
Thanks for taking the time.
JD
JD
